‎2024-07-08 08:41 PM
Hello, I was wondering if it's possible to select all elements included in a design option? Considering there are a lot of elements, objects, etc in the option, it can take a while to select everything. Any tips? Thanks!
Solved! Go to Solution.
‎2024-07-09 03:04 AM
Find & Select.
Or in the Design Options palette, set the option you want as default, and then turn on the option to 'Edit Default Only'.
Find & Select.
‎2024-07-12 06:57 AM
Amazing, I understand the design option tool much better now! Thank you!
