Design option for hotlink modules changes all settings when multiple modules are selected
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2025-01-13
11:11 AM
2025-01-13
08:19 PM
The logic for most of Archicad when changing certain settings of multiple selected objects is that only the changed settings changes. That is, if I select multiple doors with different dimensions, go to the settings and change the layer, then they keep their different dimensions and only the layer change is applied to all of them.
However if you have hotlink modules with several design options sets, say:
- module 1 has Option set 1: A, Option set 2: C
- module 2 has Option set 1: B, Option set 2: B
and I select them both and set Option set 2: A, then both of them will also get the same Option set 1 (whichever was the last module selected). Their design option sets will be identical. This is counter intuitive, against the general archicad logic, and can be very dangerous in larger projects with multiple modules that might only have small differences that could easily be missed. Hope this gets fixed/adjusted.
- Labels:
Design Options
