2025-12-04 04:56 PM
Hello everyone, we’re experiencing a very strange behavior with design options in module files in Teamwork: sometimes the variants are there, sometimes they’re not, and then only the combinations are visible. If you open the module file itself, you can see it most clearly.
We export from the project itself via the Publisher, and in the export/publish options the current story (in our case a saved view of the 9th floor) is selected, and “All elements (visible and hidden)” are included.
Either this is a bug or we’re completely missing something. We’d be very grateful for any help!
Solved! Go to Solution.
4 weeks ago
There is only one file.
The problem was resolved by leaving and rejoining the Teamwork project.
2025-12-07 01:29 PM
I wonder if this has anything to do with the Master Layer you set for placed Hotlinked Modules. Also, I assume that the layer set of the host file and the file placed as a Hotlinked Module are the same.
Also, are the Design Options, Design Options Sets, and Design Option Combinations the same on the two files?
4 weeks ago
