ā2025-12-04 04:56 PM
Hello everyone, weāre experiencing a very strange behavior with design options in module files in Teamwork: sometimes the variants are there, sometimes theyāre not, and then only the combinations are visible. If you open the module file itself, you can see it most clearly.
We export from the project itself via the Publisher, and in the export/publish options the current story (in our case a saved view of the 9th floor) is selected, and āAll elements (visible and hidden)ā are included.
Either this is a bug or weāre completely missing something. Weād be very grateful for any help!
Solved! Go to Solution.
ā2025-12-15 12:30 PM
There is only one file.
The problem was resolved by leaving and rejoining the Teamwork project.
ā2025-12-07 01:29 PM
I wonder if this has anything to do with the Master Layer you set for placed Hotlinked Modules. Also, I assume that the layer set of the host file and the file placed as a Hotlinked Module are the same.
Also, are the Design Options, Design Options Sets, and Design Option Combinations the same on the two files?
