2008-08-14 03:20 AM
2008-08-15 04:13 AM
2008-08-15 12:00 PM
Carstene wrote:Take a look at OBJECTiVE - it provides tools to create profiles and bend the to curves in both plan and elevation, which is perfect for shaping kerbs to sloping & winding edges. If you refer to the attached example, I have selected one object (out of many) created and shaped with OBJECTIVE that does exactly this (and also acts as an SEO operator for the wall below).
what is the best way to model detailed kerbs (using profiler as example) in ArchiCAD on a sloping terrain along a winding road? Is Architerra 3 any good for this? Any other software we should be looking at?
2008-08-18 01:12 AM
2008-08-18 02:59 AM
2008-08-18 10:06 PM
2008-08-19 02:49 AM
2008-08-19 10:07 AM
Carstene wrote:You cannot do curved Beams but you can approximate them with linear segments. Maybe the Radial Multiply command is what you need with some vertical offset applied during the multiplication.
- the beam tool would be great if you could do curved beams....
Cheers Carsten
2008-08-20 05:48 AM
2008-08-20 07:04 AM
Carstene wrote:You can use the Mesh to Roof add-on, but it's still pretty messy. Otherwise you have to use other 3D profilers, such as Objective, ArchiForma, and I think CadImage have one.
It would be easy solved by Graphisoft if you could "tell" the terrain tool to slope the same at the bottom as on top and then convert this to a profile!
