Zdenko
Dimensioning Project Preferences
why is it necessary to keep renaming a "store as" under project preferences for dimensions to an existing name only to "store as" under the same name. is there a solution to what seems such a simple idea of overwriting the selected preference.
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
1 Solution
Eduardo Rolon
The 25+ year workaround is.
  • Before editing the Dim settings copy the name by using rename and then cancel.
  • Edit the settings as you need
  • At the "store as" prompt paste the name
  • When you select "OK" you will get this "hidden" dialog
  • BONUS:
    • use short easy to type names and then you can ignore the first step or use a text snipping tool (I like TextSnipper) to copy the text
BTW I agree that this should have been fixed a looooooong time ago.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Go to post
2 Replies 2
Eduardo Rolon
  • BONUS:
AC29 US/INT -> AC08
another Moderator
Zdenko
thank you @Eduardo Rolon happened to stumble upon what you spelled out and have reset them to no more than 2 characters.
Sequoia 15.1.1
