Disappearing Tracker
kevin b
Anyone else experiencing this? My tracker turns off seemingly on its own. I have a WE setup with all my shortcuts and palettes etc and the tracker is set to be on. At some point the tracker no longer shows and if I go into WE it is turned off. I reapply my WE and everything is OK again. There doesn't seem to be any rhyme or reason to when it turns off.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
4 REPLIES 4
Thomas Holm
If you've got a tracker with the looks of your avatar, no wonder he gets tired sometimes!
It's happened to me also. Workaround: Turn it on again!
kevin b
I did make the tracker toggle on/off a shortcut so workaround it I did, just wondering if its happening elsewhere.
Yes she does get tired quite often, especially now, 8 years after that picture was taken, affectionately known as the 60 pound foot warmer.
kevin s burns, AIA
massachusetts, usa
Windows 10
Thomas Holm
it is. And she looks loveable. A personality. Good picture!
__archiben
there is a bug i reported during beta whereby applying the user preferences work environment scheme twice or without actually modifying it does turn the tracker off. best thing quite frankly.
~/archiben
b e n _ f r o s t
