Display Line Thinkness
Hi everyone
An original file in DXF has been imported in archicad and cleaned. Saved as PLN in Archicad 21.
There is no way to activate line thickness on the screen (printing is fine). If I open a new worksheet and draw a line I will see the correct line thickness as soon I copy part of my drawing from another working sheet in the one I see line thicknesses.... the thickness view would disappear and all line are the same.
Anyone has an explanation for this?
Thank you very much
1 REPLY 1
David Maudlin
mworld:
One thing to check is the scale of the worksheet. If the scale is large (1:1, 1:2, etc.) then you have to be zoomed very far in to see line thicknesses.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
