Display mesh cut fill in plan views
Hi guys
Not sure I put this in the right topic, but here it goes.
I am working on a project which is situsted on a steep slope and also has multiple stories ( 7-8 sets of plans).
For setting up my drawings together on one large board I would like to display the cut-fill of the mesh terrain on each story, so that you see where the plan section cuts through the mesh on each level. Is that possible?
I set the mesh to be displayed as a solid body, and played around with the cut fill and floor plan settings, but no luck so far. Any ideas would be appreciated.
Thank you!!
- Malene
alemanda
If you want to have a dynamic site you have to use the morph or convert your mesh to a morph.
Or you can use the mesh for 3D visualization and use lines and fills for floor plan representations.
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
Thank you!!
I think I will copy the mesh, convert it to a morph and use it to draw fills for the plans. (This landscape is just so complex that I need some kind of a guide to see where it is cut.)
