2008-03-1805:48 PM - last edited on 2023-05-2611:31 AM by Rubia Torres
2008-03-1805:48 PM
Hey. I'm trying to make a lighthouse with slanted exterior walls and windows and doors. The windows doors work in section and 3d, but in plan I get a blue dot. When I try adjusting parameters, I get an error message. There is supposed to be a window plane setting, but I can't find it.
Thanks all for your suggestions. I'm not sure how to do a screen shot. Found the Window Plane thing, thanks, but I get the same problem, ie: blue dot in plan. When I try to edit the blue dot, the error message is "Index value greater than array dimension @ line 158 in the Master script of the file wa_trim_us_10.gsm"
John,
Have you replaced the macro wa_trim_us_10.gsm with the one
written by Matthew Lohdon ? As I remember, it fixes an issue
involving composites. It is available in the Object Depository
under door and windows->windows (see image below).
Peter Devlin
