mukster
Door arc
what setting is it that sets to door swings to a straight line and changes it back to an arc?
1 Reply 1
Jan Millan
If you are using the Global library, it should appear under the Model View Options under:
'DETAIL LEVEL OF DOOR AND WINDOW SYMBOLS > Door Opening Line on Floor Plan'
Jan Millán
Senior Technical Support Engineer, Graphisoft
Graphisoft Certified BIM Manager
