2008-06-0412:01 AM - last edited on 2023-05-2305:00 PM by Rubia Torres
2008-06-0412:01 AM
The door object D1 Storeftont 3 10 does not show the 'opening line in 3D' correctly in an interior elevation. Please tell me I made a mistake cuz this is a nice thing to show. I included a pdf to show the plan and the int elevation. THe doors on both ends are the D1 Storefront 3 10 objects. We have the most current library loaded and we are still in V10.
Any help would be great,
Thanks,
Michele
Michele,
Your signature says you are using Archicad 10.
Graphisoft is no longer supporting Archicad 10
so they are not going to fix an AC 10 library part.
You ask if you can go back to an old door object.
I can only assume you mean an Archicad 9 door object.
Yes, you can use an object saved in a previous version
in a later version.
Peter Devlin
