2013-03-29 11:27 AM - last edited on 2023-05-26 11:17 AM by Rubia Torres
2013-03-30 11:23 PM
Dave555 wrote:The door schedule can be tricky, some of the parameters you can add are in the Parameter box last row in "Parameters for Listing", open this and you can add the location, materials, note/remarks (I add the FINISH). To get this to appear in your schedule, you need to open the Scheme Settings dialog in the Schedule itself; then at the lower left side on the bottom push the down arrow to add parameters, select add object parameters, select AC116 library, select object library 16, select openings 16, select doors and frames, select any door, scroll down till you find "location", and or "material", or anything, then push the "add" button under the window and say ok. Your schedule will reflect what you added, then you can edit the schedule as to left/right/center justification of text, box sizes, text font, 3d pictures.
Iam trying to do a automatic door schedule, but it wont show my labels.
It shows id, sizes etc but in the label colum, its all empty.
2013-04-01 10:14 PM
2013-04-01 10:46 PM
Dave555 wrote:My suggestion is that you go to page 771 in the Reference Guide and read every bit of the "Interactive Schedule" portion thoroughly. The Reference Guide can be found by going up to the Help menu ("pull down", scroll down to ArchiCAD Reference Guide, then going to the "Interactive Schedules" portion.
My problem is that my door lable that shows on the plan, wont show up in the schedule. The lable in the plan shows id, width and oritation. E.g D18L. I would like to have the same text in the schedule and even better if it could calculate the amount based on that.
