Door threshold with zone fill
I am using the cover fill in the zone tool to display the tile pattern on the floor. I would like to have this fills cover my door threshold, without modifying the zones surface area.
My door threshold is set to transparent.
I can draw fills on the threshold, but it is awkward.
Is there a setting to extend my cover fill from the zone tool, over the threshold, without manually modifying the zone contour?
Thank you!
1 REPLY 1
Ernest Atanasiu
In your examples I think it's OK if the value of the measured area contains also the sill area.
Best thing you can do is use a 0 value for the "wall recesses to zones'
The door sill (threshold) will still be uncovered, though.
arch. ernest atanasiu
AC 10-26 INT/GER/FR on Win 10/ Win 11
