2020-03-31
01:33 AM
2023-05-25
05:53 PM
Rubia Torres
Solved! Go to Solution.
2020-04-02 01:25 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-03-31 02:42 AM
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 5900X | 32GB | GTX2080TI |
2020-04-01 01:31 PM
2020-04-02 12:27 AM
2020-04-02 01:25 AM
Minh Nguyen
GRAPHISOFT
2020-04-02 02:01 AM
2021-10-07 09:19 PM
Hi
I am user of Archicad 21.
I am struggeling with the oversize and tolerance. I understand the difference between the tolerance and oversize. But am not fully understand your explanation of the oversize. If I am using a door size 1000 x 2100 mm, and want a 15 gap around the door (wall hole 1030 x 2130 mm), I would expect to see a difference between unit size and wall hole size in a door schedule.
Regards Hans.
