Doors and Windows suddenly not showing properly.
Branden Richards
Please help,
Was working on a model when suddenly doors and windows lost their sashes, and some doors and windows lost their glass texture and took on the texture of the wall behind (note the three panel sliding door became solid black like the wall it is cutting in the pictures provided).
The problem is not:
Renovation Options: Those are set to show all
The Door/Window surfaces, those are set to the correct glass surface, and in the 3D preview, the object appears properly
The Door/Window Leaf/Type, those have not changed
I cannot figure out what has happened. Please help.
Archicad 27-28, Windows 11 Pro, NVIDIA RTX 5090, AMD Ryzen 9 9950X3D 16-Core Processor - 4.30 GHz, 96.0 GB
Branden Richards
It was model view options. That was the answer.
1 REPLY 1
Branden Richards
Setup info provided by author
