Double doors not separate. Any fix?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2006-07-14
05:27 PM
2023-05-23
05:15 PM
Rubia Torres
AC26 (since AC6.0), Win10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-07-14 05:34 PM
Steve
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-07-14 11:36 PM
Apparently, it extends to surfaces within objects as well. I have a stone arch door, where the arch is made of separate stones. In 9, I get lines between them, as I would like. In 10, they all clean up.
I would think the pair of doors are touching, and cleaning up. (I couldn't say why one of them wouldn't.)
Some investigation is in order, to determine if the edges can be forced to show, with status codes or whatever. If it's controllable, it would require revised objects.
I wish GS would just say: Matching, adjacent surfaces clean up, full stop. Objects have further flexibility in the status codes.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-07-15 03:16 AM
between the panels.
I have a double door object and the panels are made with PRISM_
and they show the joint line.
I did some checking concerning prism based objects cleaning-up
with each other when one plane of each object is co-planer and touching
and am having inconsistent results.
Some times two prism based objects clean-up sometimes not.
Peter Devlin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-07-15 06:35 AM
Set the 3D opening angle to 0.20°.
Peter Devlin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-07-15 06:57 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-07-17 08:44 PM
I'm sure this is a condition that will continue to appear (or not appear) with other objects. GS needs to address this, as we cannot be expected to manually add 2D lines to our 3D objects to get them to appear correctly!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-07-17 09:01 PM
James wrote:It appears that the former part is true. All co-planar faces of like material seem to clean up to each other. This is of course a major improvent toward giving us the appearance we want in live elevations and hidden line views. It also seems to have brought improvements to sketch rendering.
I'm not sure about the latter bit. It seems that the effect of the new clean-up routines on library parts was not anticipated. One way or another this needs to be fixed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-07-17 09:24 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-07-17 09:25 PM
