Drag a copy bug
We have found a bug in archicad 9 build 2219 regarding the ctrl shortcut key to enable or disable the drag a copy feature.
What we do is:
Start draging: ctrl+d
Zoom in: ctrl+/
Now the little plus symbol is displayed and we cannot turn it off by pressing ctrl untill we zoom in again.
Is there some way to disable the ctrl shortcut key. If we want to drag a copy we will do ctrl+shift+d.
Thanks,
Adam
15 REPLIES 15
adambutler wrote:
it wouldbe nice if we could get rid of the scroll bars on the side of the screen, they dont really work properly anyway and it would mean a few extra mm's of desktop space
Of course these were added due to popular request a few years back (something about consistency with word processors etc. I guess). I agree that they don't serve much purpose in navigating an unbounded (relatively) workspace.
Link,
Stop hitting me!
I find that I move very fast and accurately with my thumb button programmed to ctrl+/ and the index/middle finger pair to previous zoom. The scroll wheel tends to be less accurate....
Chadwick
I personally become furious with any program that doesnt utilize the scroll wheel for all kinds of different combinations of commands. I am going to show my age here (LOL) but I remember being in high school drafting class when our mice switched to wheel mice and using *gasp* DATACAD 7 we could zoom and pan so much easier (The menu system in that program was abnormal to begin with anyway). I think a lot of programs have options to set up the sensitivity of the wheel for scrolling. Maybe its in the mouse software. Either way I cannot see using second hand or a series of right clicks to do things that are second nature like zooming.
Sorry, that kind of turned into thinking out loud ....
BTW, if the plural of mouse is mice shouldnt the plural of house be hice?
RA 2012 x64, Piranesi 6 Pro, Sketchup 8, Windows 7 Pro x64, Intel Core i7, 10GB RAM, ATI Radeon Mobile 5870
TomWaltz
Peter wrote:
Link,
Stop hitting me!
How accurate do you need a "Zoom" command to be? I generally find "zoom in around here" is close enough... it's not like it gets dimensioned 😉
Tom Waltz
Link
Link,
Stop hitting me!
There's an art to zooming with your scroll wheel that is blindingly obvious to most and completely unknown to some, so I will mention it anyway, just in case you fall into the latter category:
The most accurate way to zoom in (using the scroll wheel) is to hover your cursor over the exact point you want to zoom in to. If you scroll exactly over the desired target, you will zoom into it. By watching your cursor snap to a node first, you can be even more accurate. Okay it's not absolutely spot on, but it gets you close enough IMHO.
Once that technique is mastered, you can then use the same principle to zoom in and out of areas quickly, by being slightly off-target.
It's the same with pan (by pressing the scroll wheel). Hold it down where you want to pan from and let it go where you want to pan to.
As I said pretty obvious to most, but if you're still using ctrl+/ and zoom previous to zoom accurately, maybe thie above method will become easier with practice?
Link.
I use the scroll ball (Mighty Mouse) happily all day, but I do still find times when the explicit zoom command is better. The scroll is a bit jumpy and sometimes the zoom I want is in between the steps.
