Drawing Numbering Grid (Plotmaker)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2005-03-31 05:29 PM
Is this a glitch in PlotMaker or am I being a muppet
One other thing I'm puzzled by is the manual shows a grid preview where one detail covers a larger area than the other details but what I get is an equally spaced grid instead. Is there some way of customising the grid cell size?
tia
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-03-31 05:34 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-03-31 06:06 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-03-31 06:12 PM
Matthew wrote:What is puzzling is that for example in my screenshot the detail positioned over the D area is labelling it's self C and even if I tell it to reset the Autotext Reference point to a corner in the D area it still displays C in the Title label which I highlighted in my screenshot
The problem is not entirely clear from your posts. But, I am guessing that it has to do with the positioning of the drawings on the sheet.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-03-31 06:34 PM
The drawings are numbered based on their lower left corner position. Whichever numbered grid square contains that corner of your drawing will be the number plotmaker assigns.
Hope that's clear enough to understand.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-03-31 06:38 PM
Thompson, wrote:But you should be able to change it from the bottom left to any corner you like by using the pop-up menu item. Sadly it doesn't seem to be working for me
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-03-31 07:12 PM
Also just play around with the setting above... your original question asked about this as well.
woodster
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-03-31 07:19 PM
I still think there is glitch though because according to the manual you should be able to set it yourself for each individual plot file by using the pop-up menu.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-03-31 08:24 PM
fuzzytnth3 wrote:Look at this wish an vote for it:
That sort of worked now one of the other details is now wrong due to it spreading across two cells. The result is I have details labelled A, B, C, D, F and G whereas before I had A, B, B, C, E G
Thanks,
Joseph
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-04-03 12:45 AM
