Drawing Title
Please help me, how to create drawing title and how to edit drawing title.
Cheers
Pandji
5 Replies 5
Eduardo Rolon
1) Select drawing that has the title
2) File- Libraries and Objects -> Open Object
3) Select - Edit Full View
4) Edit
5) Save As Title Type
for a new title start with "New Object" from the "Libraries…"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
thanks for your reply mr.Ejrolon, but i'm still confuse because i'm not understand about GDL. I only want to add text "Scale" before the text 1 :100. So it'll show "Scale 1 :100" below the drawing name. Thanks.
(please look at my attachment)
Cheers
Pandji
Eduardo Rolon
That is a different question,
right click on your drawing and select "Drawing Selection Settings" Under the Title Tab you will see a list of settings based on the type of title selected.
AC29 US/INT -> AC08
Thanks, its great, problem solved. i'm using AC10 so it has different with AC 11 in parameter list of setting.
That's why it is recommended that all forumites list their machine specs and Archicad version in signature (within your profile, button above)
