2004-10-28
05:08 PM
2023-05-26
03:20 PM
Rubia Torres
2004-10-30 02:01 AM
2004-10-30 03:47 AM
Djordje wrote:Djorde, Thats a good idea and of course can do it in elevations view too.
Select the placed one, view it in 3D, set your Special snap points to 3 divisions, drag mullions in place. No math required.
2004-10-30 03:52 AM
2004-10-30 04:37 AM
Aussie wrote:The problem is that this should not be necessary. As Adalbert and I agree elsewhere, library parts are in serious need of improvement. You shouldn't have to have a one size fits all door just to preserve common parameters.
And yes an all singing and dancing object becomes absurd to script. That said I try to use only one door type (that has many options including roller, multifold, sliding, double, single, fanlight, frameless etc) as it means i dont have to resize it if I change to a different type of door.
2004-10-30 04:49 AM
Aussie wrote:Knowing the mullion width, you can always start the Special snap point rubberband at a relative coordinate - half a mullion - from the opening end and end it before.
If the window sets the middle mullions out by the centreline then your method wont give you equal width glazing panels as the end mullions are setout by the outside edges. Hence the outer panels will be half a mullion narrower.
At least in elevation view you can draw a line (length less one mullion long) and use that for the division points.
2004-10-30 05:39 AM
Djordje wrote:Different views (of the model) provide different features and advantages. I frequently switch views to do various tasks. For example: nothing beats the section window for precise fitting of roofs, walls and eaves details; the plan window is still the easiest place to layout furniture; for doors and windows I switch between all three.
Now, why people who realize the advantages of the Virtual Building insist on working in plans, sections and elevations, is beyond me ...
2004-10-30 05:46 AM
2004-10-30 07:17 PM
Dwight wrote:... as the audience is smothered by the warm, fuzzy feeling ...
[With enthusiasm]
"But, Djordje and Matthew, you are both right! Even if we are working orthographically, the Virtual Building provides an information link and instant update between all views vital to productivity in the new millennium."
[Turn, smiling, to camera. Hold up ArchiCAD 9 box. Rooster - since c*o*c*k was censored - [what shyte!] head inquisitively.]
