We value your input!
Edge of wall joined with curved wall
lssthln
Is there a way to get the edge of a straight wall to stay straight when being joined with a curved wall ?
Thanks.
David Maudlin
lssthln:
Try adding a short straight wall segment to the end of the straight wall.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
7 REPLIES 7
Hi @lssthln,
You can put any of them on a different layer with different intersection group number then they won’t intersect.
AC 27 INT 5060/WIN 11
lssthln
Sure, thanks.
Maybe I'm too picky but actually I would like them to intersect because they do in reality.
Was wondering if there was a setting that would prioritize the straight edge over the curved wall.
You can use display order function to bring forward or send to back.
David Maudlin
lssthln:
David
lssthln
obviously but whatever object is in front there will a be line between the walls if they don't join.
Plus this would just affect Plan view and not make my model right
Yes, the reference lines should join.
Looks correct in 3D to me.
David
thanks, simple but fine 🙂
