Thursday
Is there a way to get the edge of a straight wall to stay straight when being joined with a curved wall ?
Thanks.
Solved! Go to Solution.
Thursday
Try adding a short straight wall segment to the end of the straight wall.
David
Thursday
Hi @lssthln,
You can put any of them on a different layer with different intersection group number then they won’t intersect.
Thursday
Sure, thanks.
Maybe I'm too picky but actually I would like them to intersect because they do in reality.
Was wondering if there was a setting that would prioritize the straight edge over the curved wall.
Thursday
You can use display order function to bring forward or send to back.
Thursday
David
Thursday
obviously but whatever object is in front there will a be line between the walls if they don't join.
Plus this would just affect Plan view and not make my model right
Thursday
Yes, the reference lines should join.
@lssthln wrote:Plus this would just affect Plan view and not make my model right
Looks correct in 3D to me.
David
Thursday
thanks, simple but fine 🙂
