2024-06-27 12:02 PM
Is there a way to get the edge of a straight wall to stay straight when being joined with a curved wall ?
Thanks.
Solved! Go to Solution.
2024-06-27 01:18 PM
Try adding a short straight wall segment to the end of the straight wall.
2024-06-27 12:12 PM
Hi @lssthln,
You can put any of them on a different layer with different intersection group number then they won’t intersect.
2024-06-27 12:34 PM
Sure, thanks.
Maybe I'm too picky but actually I would like them to intersect because they do in reality.
Was wondering if there was a setting that would prioritize the straight edge over the curved wall.
2024-06-27 01:09 PM
You can use display order function to bring forward or send to back.
2024-06-27 01:18 PM
2024-06-27 01:21 PM
obviously but whatever object is in front there will a be line between the walls if they don't join.
Plus this would just affect Plan view and not make my model right
2024-06-27 01:32 PM
Yes, the reference lines should join.
@lssthln wrote:Plus this would just affect Plan view and not make my model right
Looks correct in 3D to me.
2024-06-27 01:42 PM
thanks, simple but fine 🙂
