Edge visibility of wall in plan
ratnabhirud
Why edge of the same wall is showing different in plan. (AC ver. 14)
Attaching snap shot .
Regards,
Ratna
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
10 REPLIES 10
In case of Wall 2, you may actually have two instances of the same Wall on top of each other. Or there is another shorter Wall there. That is one case that can cause this behavior.
ratnabhirud
Thanks,
But I have checked this wall, it is single and continuous i.e. 1 and 2 is one single wall.
Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
Have you turn all invisible layer? You could have a wall on same location on invisible layer or different storey and same height
ratnabhirud
hello Baby Boon,
I have checked this also.
may be software bug?
Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
ratnabhirud wrote:
hello Baby Boon,
Regards,
Ratna
Hi Ratna,
Could you upload your model to check this ?
I think there's various way to cause this problem! Last time I had similar issue when "a complex profile wall" touch another wall accidentally and they intersect each other automatically. it's harder to explain here than check the model.
ratnabhirud
Hello Riiiiv,
Actually the zip file is still 1.56 mb , so can't be able to attach as per Forum rule.
This is very simple plan and there is no Composite or Complex wall.
Just for your information , I used Split command in other case but not in attached image.
Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
ratnabhirud
Hi Riiiiv,
I can not upload the project file as it is @2.2 mB. Instead you can download it from this link:
File
Ram - 16.0 GB
Archicad 9..., 24
ratnabhirud wrote:
Hi Riiiiv,
File
Hi ratna,
I've checked your model and if I'm right the column C10 at mid of wall W2 cause problem. Could you try to delete that column? Is it back to normal?
What I've seen here is that column wasn't in the right angle (not PERFECTLY parallel with axis X). Could you try to rotate it back and check the result?
ratnabhirud
Hello Riiiiv,
You found the problem correctly,
Thank you very much.
Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
