‎2021-10-04 04:47 PM
I've done this before to edit the exterior skins on a wall to be lower than the entire profile
It worked a few times correctly
I select the item
Right click
Edit/Select Composite Profile
and it came up with the Profile Editor.
NOW on any wall I select it comes up with the Composites dialog
Now every time I select a wall I get the wrong dialog.
Or is there some thing I am missing
‎2021-10-04 10:51 PM
You can change heights of finishes in custom profiles but you cannot change height of finishes from the composites.
‎2021-10-05 12:10 AM
It was my total forgetting.
IT was simple. I needed to select the wall, change to a compound profile then it would let me edit where I change the height and increased the lower depth of the skins on the wall.
So much to learn so I forget something every now and again. Thanks for the reply back.
‎2021-10-05 03:10 AM
And now you want to look into adding 'Modifiers" to your complex profiles - more to learn.
Then you can adjust the heights and widths of the components of the complex profile on a wall by wall basis in section/3D rather than having to edit and re-save a new profile for each variation in skin height.
‎2021-10-05 04:03 AM
Actually am already doing that as it is so easy in this program. I just forgot a step along the way. I don't use this every day and when learning that can impeed you a bit.
‎2021-10-05 04:42 AM
Just use wall coverings for all my sheetrock baseboard and sheathing and framing all in one much easier for me to get the desired outcome I want
