Elliptical (oval) stair
is there a way to design a spiral stair with solid side wall based on an oval shape?
38 Replies 38
Dwight
model it with walls and slabs.
Dwight Atkinson
That's what I thought, but how can you get the side wall to follow the tread of the stair (like a spiral?)
Dwight
you draw a curved wall and smack the treads on.
make a sketch.
Dwight Atkinson
See here:
...and here
You can model such a wall with a curved wall, as Dwight says, and then trim the top and bottom of it by using the curved ramp object in the library.
Or, you can purchase the Objective add-on which makes sloped extruded curved objects pretty straightforward:
http://www.encina.co.uk/objective.html
but, the result is an object and not a wall, in case that matters, so no section skins, core-only, etc. See also this thread:
http://archicad-talk.graphisoft.com/viewtopic.php?p=126434&highlight=curved+wall+objective#126434
But isn't the curved ramp based on a circle? My stair is oval...
Dwight
CLose enough, but not a smooth trimmer.
Dwight Atkinson
Dwight
closer view
Dwight Atkinson
