Elliptical Stair with Two Landings
Help plesae! I need to make an elliptical stair with two landings, but can't get stairmaker to let me do what I want. Any suggestions?
6 Replies 6
Dwight
How detailed does it need to be?
You could always model a elevating slab array and yank them into place....... the 3D profiler would make a handrail, nore-or-less.......
Dwight Atkinson
Thanks for responding. I'm not quite sure how to do what you just suggested. Could you walk me through it? The height of the stairs needs to be +12'-6" from project zero, width of the stair 4', rise" 6" run 12".
Dwight
three phases:
The layout:
- work out the plan array of the stairs - use lines arrayed from the centroid of an ellipse - this is plain drafting.
The vertical displacement:
- make a tread from a slab to your thickness and multiply the slab with vertical displacement equal to your needs - make a straight run - spin them around the center of the ellipse in a circle....whatever.
Put them together:
-- drag the stepped slabs into the array one at a time, and resize them.
Dwight Atkinson
I'll try it thanks!
Dwight
Sometimes the old ways are the only ways.
Dwight Atkinson
Djordje
Do the flights as one stair each, landing as a slab, group.
Or, when finished, save as a lib part. That is, if you expect no changes (ha!).
Also, try ArchiStair ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
