Due to a scheduled maintenance, a maximum 20 minutes license delivery outage may be expected on July 6 2024 (Saturday) between 6PM to 8PM (CEST).
Elliptical Stair with Two Landings
Help plesae! I need to make an elliptical stair with two landings, but can't get stairmaker to let me do what I want. Any suggestions?
6 REPLIES 6
Dwight
How detailed does it need to be?
You could always model a elevating slab array and yank them into place....... the 3D profiler would make a handrail, nore-or-less.......
Dwight Atkinson
Thanks for responding. I'm not quite sure how to do what you just suggested. Could you walk me through it? The height of the stairs needs to be +12'-6" from project zero, width of the stair 4', rise" 6" run 12".
Dwight
three phases:
The layout:
- work out the plan array of the stairs - use lines arrayed from the centroid of an ellipse - this is plain drafting.
The vertical displacement:
- make a tread from a slab to your thickness and multiply the slab with vertical displacement equal to your needs - make a straight run - spin them around the center of the ellipse in a circle....whatever.
Put them together:
-- drag the stepped slabs into the array one at a time, and resize them.
Dwight Atkinson
I'll try it thanks!
Dwight
Sometimes the old ways are the only ways.
Dwight Atkinson
Djordje
Ace
Do the flights as one stair each, landing as a slab, group.
Or, when finished, save as a lib part. That is, if you expect no changes (ha!).
Also, try ArchiStair ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
