Exploding a morph into the individual faces would be a possible workaround to schedule surface areas of individual faces, which is (still) not possible in ArchiCAD.
E.g. to do a quick heat-loss/energy estimate based on a "Mass Model" (the way many people use Revit or SketchUp in a concept phase).
In the example below, I created a single Morph Volume with the desired outer shell of a house. Placed it on a separate layer.
On a copy of the volume, I manually selected each individual face, assigned a Surface and turned the selection into a Morph (so it got detached from the volume). This individual flat morph can then be placed on a proper layer.
I created two schedules and filtered out the morphs according their layers.
This is a very labour intensive effort, but is the exact result I would like to obtain in one step, namely by being able to schedular surface areas of all faces of the morph.
Archicad-user since 1998
my Archicad Book
