2024-05-07 09:40 PM - edited 2024-05-07 09:40 PM
[I may have seen this mentioned before but can't find it now.] On AC 27 USA, Mac M1 Max, MacOS 13.6.6, option-clicking on a wall and opening Element Attributes > Composites… will not show that composite selected. Changing the view from folders to list before or after does not change anything. Is there any Work Environment setting or something that I am missing? How are you handling this? It can't be meant to work like this, it all becomes unmanageable.
Solved! Go to Solution.
2024-05-07 09:53 PM
Hi @Ignacio Azpiazu,
There’s another & easier way to open any composite directly, by selecting + right click + Edit selected composite.
This way is applicable for complex profile elements also.
2024-05-07 09:53 PM
2024-05-07 10:39 PM - edited 2024-05-07 10:51 PM
That does the job with composites. Thanks.
I still think it is a pain to have lost the other method though, which I just checked and still works for building material, including solid single-material walls. So it is sort of complicating the interface.
2024-05-09 12:59 AM
Try to enter the Attribute Setting Dialog with the element selected. It works for me (I just tried it in Ac27).
2024-05-09 01:05 PM
If by Attribute Setting Dialog you mean the same thing you access by right-clicking and going Edit Selected Composite/Profile…, it is not taking me to its attribute in AC 27 5003 USA Apple Silicon.
2024-05-12 06:01 PM
That's weird. It should take you there. It does work just fine in Ac27 on Windows.
Could this be a Mac-specific error?
