File size
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2010-09-28
01:12 PM
‎2023-05-26
03:22 PM
Rubia Torres
Is it lots of imported PDF/DWG, large number of layers or other attributes, large number of views, massive amount of layout's or loads of modules ( as .mod or .pln)?
I'm asking because I need to reduce file size of a project and would like to know where to attack.
PDF's and DWG's are gone and I'm about to clear the layer list from DWG-layers, anything else I could get rid off or slim down.
The file is a TW2 file @ 1.4 Gb (uncompressed I know) and it's causing a bit of problem for my user (slow loading, occasionally chrashing).
In short, what is the best way to reduce file size?
- Labels:
Attributes
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-10-01 02:52 AM
Publishing take very little time compared to linked views
Once you have "published' your pmk files and linked them all thru there is no "update" time as the layout book looks directly at a particular PMK file if you update it the layout book automatically updates in seconds.
I find that "updating in seperate archicad" take so long when using large files (my model file takes approx 12mins to open) so all of the waiting time is eliminated.
You could have a person updating PMK files in the model and another user using the layout book file any changes made and re-published are automatically available.
This may be considered an "old method" but is the best system i have come across when using large files.
And like i said you can archive old PMK files so you have a full revision history if required.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-10-03 09:04 PM
Lasse wrote:There should be no problem opening the file on a 64bit machine. The files are not changed and are fully compatible across Mac and Windows in both 32 and 64 bit versions.
I've been careful not to open the project on my 64-bit computer.
The warning GS provides is just to remind you that by working in 64bit you can make the file too large and unmanageable to revert to using it on a 32bit machine.
Since you are tuning the file for performance on 32bit you naturally have to test it on that machine, but if it is quicker to make the changes on the better machine that should work just fine.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-10-11 09:47 PM
Can I ask how you deal with your "marker references" when using pmk files?
We have a huge amount of Sections and Elevations that are referenced using "The first placed drawing of the viewpoint" in the selection settings. By publishing pmk files for use in separate file don't you lose the automation built in to the markers?
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-10-12 11:05 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-04-12 05:58 PM
Lasse wrote:
Does anyone know what's the most file size consuming things to look for in a ArchiCad file.
Same situation, but mostly our problems come when we need to load the file on another computer before a client meeting and it takes forever.
There is one TW project that we have now weighing in at a hefty 4545 MB.
I am about to start experimenting with the effects of the "store drawing in project file" option. See this post:
Does anyone know more about what this option does? Where do the drawings go if they are not stored in the project file? How is this effected by teamwork?
UPDATE: The same project 4545MB TW Project is only 770MB when saved as a PLN. Can someone explain the difference?
Thanks,
ArchiCAD 15
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-04-16 06:03 PM
In the Save Dialog, click the Options button to check it.
This 770 MB PLN sounds enormous to me.
If no compression is used and you check it it should go well below 200 MB.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-04-16 06:07 PM
Otherwise it is read from the location given in its path.
If you don't move the Drawings then this is no problem.
But if you want to view the file on another computer that should also have access to the Drawing at the store file path. In a LAN this can be done by storing those drawings on a server.
If viewed in another office... that's a different story.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-04-16 09:15 PM
Linked files/drawings work in WAN too, if only have access to the server.
Regards, Juha
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
