File won't open - Freezes Archicad - What can I do?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2004-03-15
04:06 PM
‎2023-05-25
06:23 PM
Rubia Torres
‎2004-03-15
04:06 PM
The file was working fine. I was working with it in Archicad 8.1 with no problems previous to this. I can also open other Archicad projects without any problem.
Any thoughts as to how I can open this file?
(using Archicad 8.1 on PowerMac G4/500, 384 mb RAM, with OSX 10.3.2 (Panther))
Thanks - Stephen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-03-15 06:27 PM
‎2004-03-15
06:27 PM
Stephen wrote:Try the "forward merge" technique as described by Eric Batte (in Tips&Tricks forum).
I have an Archicad Project file that I can't open.
Before that, delete the library cache and the preferences - this should help.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
HP Omen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-03-22 09:36 AM
‎2004-03-22
09:36 AM
Stephen wrote:try starting a new (or new & reset) file then merging the corrupted file. Works sometimes.
I have an Archicad Project file that I can't open. It seemes to be corrupted in some way, because when I try to open it Archicad 8.1 completely freezes. The colored wheel just keeps spinning. I can't even get it to quit with Force Quit (I've never had that happen with any application). Any other running applications will still run fine during this process, but I have to restart the computer to be able to use Archicad again.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-03-22 06:22 PM
‎2004-03-22
06:22 PM
Djordje wrote:After causing a crash (well ... two ArchiCADs and a PlotMaker updating from two files, meaning FOUR ArchiCADs and a PlotMaker are really too much ... duhStephen wrote:Try the "forward merge" technique as described by Eric Batte (in Tips&Tricks forum).
Djordje
HP Omen
HP Omen
