Tom Krowka
Fill on surface of mesh
Any way for the fill to run with the contours of a mesh? Am using mesh for a ground plane in site plan and would like to use parallel lines running in the same direction as the mutiple varied mesh surfaces.
Don't see any way to do this.
Thanks.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
3 Replies 3
NCornia
Graphisoft Alumni
Graphisoft Alumni
Tom,
There is not a way to do this with the Mesh tool but you could use the Mesh to Roof add-on and then align the fill on each individual panel. The amount of time involved will probably outweigh the benefit of doing this though.
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Tom Krowka
You're correct about time. Could just regular fill overlay and eliminate mesh to roof step. It would be a nice feature for site plans.....but thanks anyway.
Tom
[email protected]
www.walshkrowka.com
Pretty easy for a material (texture image) ... create a custom image that maps exactly onto the mesh. But, don't know of a way to do it with fills... Or of any way to do it dynamically as a mesh shape is changed...
Karl
