Fillet edges wall-to-slab
Hi, I have been using the fillet/chamfer tool on walls to fillet their intersections. I have used the fillet tool on the corners of slabs. Now I am trying to fillet the edge where a wall intersects a slab. A perfect example of what I am trying to do is the image that you see when you open Archicad 10 Student Version. The wall-to-slab intersections in that image have a fillet. I can't get that to work and haven't found anything about that online. I was wondering what tools were used for that or if it requires Maxonform.
Thanks
2 Replies 2
If you are using AC 10. You may use "complex profiles " to create custom wall,colomn and beams.
1-you have to create your wall by using coplex profiles.
2-in wall settings choose the comlex wall icon and choose the profile that you created.
Or use an object from the Basic Shapes library.
