2007-08-15
04:53 PM
2023-05-23
03:16 PM
Rubia Torres
2007-08-15 05:38 PM
2007-08-15 05:47 PM
2007-08-15 05:48 PM
2007-08-15 06:47 PM
Scrat wrote:Did you try to just draw a wall at the edge of the stair and sidewalk?
I tried with Fill Tool but got no results. I need to fill marked (with red line) space.
I tried to do something like trim to roof (trim to stairs) and with SEO tools but neither gave me a result
2007-08-15 09:23 PM
Steve wrote:Personally I'd recommend only making the wall/slab the maximum height it needs to be - no more. In this case do it to the underside of the landing. You will end up with nodes floating around in unexpected places otherwise, which can be confusing/untidy.
...Make sure it is taller than the sidewalk/landing...
2007-08-15 09:38 PM
2007-08-15 10:16 PM
Where is the extra SEO? Do you mean oporators?Hi Steve,
Could you tell me more about the slowdown with extra SEO's?
I did not know about this. I could use a lot less of them if it will help speed things up. I have been using lots of them.
2007-08-15 10:59 PM
Steve wrote:This is correct (maybe there are more ways but I made it with this one
Place the bottom of it at the same level as the bottom of the stair.
Make sure it is taller than the sidewalk/landing and use SEO to trim it to the underside of your stair and sidewalk/landing.
Sidewalk and stair = Operators, Wall = target, Subtraction with upwards extrusion.
2007-08-15 11:55 PM
