‎2007-08-15
04:53 PM
‎2023-05-23
03:16 PM
Rubia Torres
‎2007-08-17 02:13 AM
‎2007-08-17 08:16 AM
‎2007-08-17 01:21 PM
‎2007-08-17 06:47 PM
‎2007-08-19 08:02 AM
‎2007-08-19 04:36 PM
‎2007-08-19 06:50 PM
Djordje wrote:Yes. I can see how that is not a good thing to do.
Steve,
Please refrain from posting inline images. They are too big, and slow down the browsing of the contents too much. We all appreciate your intention to clearly illustrate the examples and show your work, but please don't do it at expense of the Talkers with slower connections.
Go to a dial-up computer and try looking at this topic. You will understand.
It would be appreciated if you replaced the inline images in your posts by the inserted images.
Thanks,
‎2007-08-19 09:58 PM
jean-luc wrote:or use the outline, create a fill and create a custom profile. same result as above, but maybe a bit quicker to update if your stair changes.
If you want to avoid SEO, you may use a cross section
in order to pick up the outline of your fill as polyline. Use the outline
of your fill to create a slab with the correct depth. And make a object
with the slab (ROTX 90 or from the camera view). When possible
I also guess it is better to avoid SEO.
regards
Jluc
‎2007-08-19 10:41 PM
