Fills+window background
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2014-05-14
06:30 AM
2023-05-26
02:21 PM
Rubia Torres
The attached image shows two fills side by side,
- both are 25% Pen 1 (Black)
- Left is set to window background colour, Right has the background set to a white pen.
Obviously the background of the window is white - so any ideas why the fills look so different? (did I miss an override somewhere?)
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-05-14 07:39 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-05-14 07:51 AM
Or at least the same values as each other?
I just change my background to white and could see no discernable difference.
I just check the "Automatic pen colour visibility adjustment in model views" option in the Work Environment (on screen options).
This makes a slight difference as it will be changing the white pen to grey if you have that option turned on (I always thought it went black on a white background but there you go! - that's one reason I don't use white as a background).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-05-14 10:34 PM
I didn't know about that automatic adjustment, thats useful. However, that only makes a slight difference to the colour. As you can see the difference is quite substantial.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-05-14 10:39 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-05-14 10:41 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-05-14 11:05 PM
- toggle the background fill override
- chose a colour,
- chose the window background again
- toggle the override back off
that seems to get the "-1" to appear
The brick material fill on the left is how it appears as default, and the right is after the background has been toggled on and off.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-05-15 04:44 AM
Does the same thing happen for a regular cut fill or drafting fill?
Go into your fill (surface) settings and make sure the background pen is set properly there.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-05-16 01:04 AM
It happens to all fills (cut/building material - anything that uses the background pen).
Whenever the fill background box doesn't display "-1" beside it then the background colour comes in as a dark grey.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-05-16 02:28 PM
I could only achieve a difference when I turned on the "Automatic pen colour visibility adjustment in model views" option in the Work Environment.
Otherwise both fills looked the same.
I am wondering if this might be graphics card driver related.
Could you save these fills as a PLN and share it on Dropbox or something similar and post the link? I would like to look at the file. If it works on my computer but not on your, then it may be hardware or driver related.
