2014-05-1406:30 AM - last edited on 2023-05-2602:21 PM by Rubia Torres
2014-05-1406:30 AM
Hi I'm having a little issue with fills.
The attached image shows two fills side by side,
- both are 25% Pen 1 (Black)
- Left is set to window background colour, Right has the background set to a white pen.
Obviously the background of the window is white - so any ideas why the fills look so different? (did I miss an override somewhere?)
Your fill tool has a '-2' pen set for the background default pen.
I don't know where a '-2' pen comes from.
But if you set your default fill tool to the background pen colour (-1) then all future fills will be fine.
Any existing fills you will have to amend as well.
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
I am thinking that those Fills might have come from a DWG/DXF file because there are RGB pens in AutoCAD.
But it is still strange to see -2 as background pen, I have never seen anything like it before so I will report this to GS, there may be something going on here.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
