Find & Select Renovation Status
kevin b
Why is the Renovation Status not always available as a criteria in the Find & Select dialog box?
It seemingly appears and disappears and I can't figure out why. I'm assuming there is a setting somewhere that is getting toggled, or something else I have turned on or selected is causing it but I can't figure it out. Something in display options maybe?
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
5 REPLIES 5
David Maudlin
kevin:
One possibility is that you have an Element Type (like the Section Tool) selected as a criteria, which does not have a Renovation Status.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
kevin b
Thought of that but no, walls for instance sometimes do not have renovation status available as a find and select parameter, but only sometimes.
I will post some images of example from same project, opened at two different times. Attached here is with it not available.
kevin s burns, AIA
massachusetts, usa
Windows 10
kevin b
Same file, opened at different time.
kevin s burns, AIA
massachusetts, usa
Windows 10
kevin b
Anyone else running into this? Know a cause/solution/workaround?
kevin s burns, AIA
massachusetts, usa
Windows 10
Da3dalus
I've never seen the Renovation Status pop up as a Find option... at least you got lucky a few times!
Generally, I change my Renovation Filter to one that only shows the elements with the status I want to select and alter. This requires that your template have every combination of Renovation Filters available (new only, demo only, existing only, new + demo, new + existing, existing + demo, and show everything).
Chuck Kottka
Orcutt Winslow
Phoenix, Arizona, USA
ArchiCAD 25 (since 4.5)
Macbook Pro 15" Touchbar OSX 10.15 Core i7 2.9GHz/16GB RAM/Radeon Pro560 4GB
