2013-04-24
08:03 AM
- last edited on
2023-05-25
05:59 PM
by
Rubia Torres
2013-04-24 01:38 PM
2013-04-24 02:20 PM
2013-04-25 04:58 PM
2013-04-25 05:07 PM
Matthew wrote:I haven't really used Automator. But it should be able to record anything you do on your Mac. So if you click "record" and then open ArchiCAD and make the actions, you should be able to replay them. But other than that, not sure 😕
James,
Can Automator control ArchiCAD actions? I don't see how this would work
2013-04-25 05:17 PM
James wrote:I didn't realize it could do that. I'll have to check it out sometime. Thanks.Matthew wrote:I haven't really used Automator. But it should be able to record anything you do on your Mac. So if you click "record" and then open ArchiCAD and make the actions, you should be able to replay them. But other than that, not sure 😕
James,
2013-05-02 08:52 PM
Matthew wrote:Matthew,
James,
I haven't checked lately but I vaguely recall an option to import multiple files into separate layouts. If this is correct and the sizes and scales are consistent it could be fairly easy.
