Learn more
Fixed Wall Connection
I have a 9' high wall and a half wall, and I want them to be connected always. Is there a way to maintain their connection automatically whenever I stretch one of the walls?
Also, how can I define the position of the window so that it always stays in the middle of the wall it's on whenever I change the wall's length?
Thanks.
2 Replies 2
Eduardo Rolon
None of those options are available in AC.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
The only intelligence ArchiCAD has here is that if you have Walls that form an L-connection (joining at their ends), then you can select both, in which case you will be able to edit them like segments of a polyline. In this case if you offset one Wall, the joining Wall's length will also change to follow and keep the L-connection.
Unfortunately this does not work with T- or X-connections.
Click the image to see the animation.
