The only intelligence ArchiCAD has here is that if you have Walls that form an L-connection (joining at their ends), then you can select both, in which case you will be able to edit them like segments of a polyline. In this case if you offset one Wall, the joining Wall's length will also change to follow and keep the L-connection.
Unfortunately this does not work with T- or X-connections.
Click the image to see the animation.
