KeesW
Flat slab with sloping top surface
Gurus
Is there an easy way to draw a concrete floor slab with a flat underside but sloping top? One often has to construct slabs for outside decks that incorporate a slight falls for drainage. It is not the same as drawing a ramp because these have sloping undersides and tops.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
11 Replies 11
laszlonagy wrote:
NCornia wrote:
Perhaps this wiki article by AC wizard Laszlo Nagy has something that may help: http://www.archicadwiki.com/FlatTopRoof
this is nice.
TMA_80
Hi ..again
I've been exploring the new shell tool and obviously , it doesn't resolve the problem .... no way to have changes in thikness when adding points with different altitudes in the shell tool
(it is also impossible to add point inside a shell )
AC12_27 |Win11_64bit|
