I think I still don't understand this setting. I'll explain my question as simple as I know. I have equal walls in the same story, 1st wall base elevation:-2,95m, top elevation:-0,55; 2nd wall b:-1,91m t:0,49m - both wall height is 2,4m. When in 2D view, I can't see lower based wall hatch pattern, while the upper hatch is normally visible. I think there is a problem with floor plan cut plane setting, but I can't set it right.
I hope someone can help me with this.
Thanks in advance,
Rok
