Function "edit module in another archicad"
Agence 88
Hello !
I don't know if other has the problem, but the "edit module in another archicad", which would be super useful while selecting an object in the 3D view, doesn't actually work when I click on it. Would be appreciated if anyone had a solution, or if Graphisoft could solve the issue. Thanks guys ! 🙂
4 REPLIES 4
Are you asking for a solution as a developer, or did you just post to the wrong forum?
Versions 6.5 to 26
julienK
Groups needs to be enabled  for this function to work.
From your screenshot only one column is selected.
Agence 88
Thanks julienK, it's awesome : yes with groups enabled it works well !
So this is not a programmation/technical issue.
Best,
Hello Barry Kelly ! Wasn't sure about the best forum, but julienK solved it. Thanks !
