GO and uncut objects in 2D
Kamelite
I'm trying to set up a GO that displays framework in 2D. Coloumns are shown as I want them to, but beams do not,
This is the GO for this particular view:
In 3D - everything looks as it should.
The only explanation iI can think of is that the column is cut by the Cut plane, the beam is not..Any thoughts?
.Kamelite
Windows 10, Archicad 28
2 ACCEPTED SOLUTIONS
Activate the cover fill for beams.
AC 28 INT 5200/WIN 11
Activating cover fills worked like a charm !
Thanx a lot!
.Kamelite
4 REPLIES 4
Steve Jepson
It is related to the elevation of the beam, but it seems to me that it should work to add some Positioning to the rule. ?
I am also not getting it to work as expected.   You can of course change the Cut Plane for the View to be above the bottom of the beam, but that is not a great solution.
Thanx a lot!
.Kamelite
You're welcome,
I'm happy to know it worked well, thank you.
