General rotation function
Is there a simple way to rotate any object/wall/slab/geometry on any axis or combination of axes? I have been assuming there was and that I just hadn't located the button yet but I'm beginning to think that is an incorrect assumption.
I know you can rotate a beam by typing in a slope. Is there any common function or button that works on any geometry to rotate the item in the x, y and z axes?
26 REPLIES 26
Dwight
That is great!
Your move, even tho it is complex, combines so many things!
I never considered what SEO "intersection" might mean.
Ooo, baby!!!
Dwight Atkinson
__archiben
Dwight wrote:
Ooo, baby!!!
just don't be looking for a floor plan drawing at the same time though!
b e n f r o s t
Dwight
Floor Plans are for minions.
Dwight Atkinson
~/archiben wrote:
definitely a wall - you can still put windows and doors in . . .
b
Good stuff!
WOW! Lot's of great responses. The pictures help so much on seeing what ArchiCAD is capable of in experienced hands. My goal was to use the circular slab at a 90 degree angle as an SEO operator to cut an arch in a wall and then save that shape as a GDL model. So far my work arounds to issues like this always fall back on "write the object with GDL".
Whenever I create an object just to use it in an SEO operation is it bad to delete the object once the operation is performed? I see alot of references on the forums to simply placing the object on a hidden layer.
Also, do more practiced users tend to use SEO's for alot of their needs or create objects with scripting/modeling? So far I find it easier to create the object through scripting. But it seems like I should be more comfortable with SEO's and that SEO's would work quicker than writing several lines of code to get a desired shape.
Dwight
My advice is that if an element exists in the library, you should use it.
Writing code is very time consuming.
In this case, the easiest solution if you aren't putting a window in your disk is the cylinder 11 object. It tilts to any angle without distorting.
Deleting an SEO operator eliminates the operation but it remains valid if hidden. I think. But SEO is inefficient from a 3D imaging POV since there are extra steps for the model.
As for writing the object, unless there is a productivity payback or a specific technical requirement, why would you bother?
Dwight Atkinson
To repeat Dwight's answers, phrased a little differently:
Do not delete the operator, it will void the SEO. We have a layer, A-Work-SEOs for operators we want to keep hidden, the layer is hidden in all output Layer Combinations.
If it's a one-off situation, model the Object. If it's an Object you may get a lot of use out of in multiple Projects, or you need the Object to be parametric, definitely script it (if you know how).
