General rotation function
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2008-02-29
03:19 PM
‎2024-06-03
12:41 PM
Aruzhan Ilaikova
I know you can rotate a beam by typing in a slope. Is there any common function or button that works on any geometry to rotate the item in the x, y and z axes?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-03-02 04:17 AM
Your move, even tho it is complex, combines so many things!
I never considered what SEO "intersection" might mean.
Ooo, baby!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-03-02 04:24 AM
Dwight wrote:just don't be looking for a floor plan drawing at the same time though!
Ooo, baby!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-03-02 04:28 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-03-03 10:31 AM
~/archiben wrote:Good stuff!
definitely a wall - you can still put windows and doors in . . .
b
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-03-03 04:29 PM
Whenever I create an object just to use it in an SEO operation is it bad to delete the object once the operation is performed? I see alot of references on the forums to simply placing the object on a hidden layer.
Also, do more practiced users tend to use SEO's for alot of their needs or create objects with scripting/modeling? So far I find it easier to create the object through scripting. But it seems like I should be more comfortable with SEO's and that SEO's would work quicker than writing several lines of code to get a desired shape.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-03-03 04:49 PM
Writing code is very time consuming.
In this case, the easiest solution if you aren't putting a window in your disk is the cylinder 11 object. It tilts to any angle without distorting.
Deleting an SEO operator eliminates the operation but it remains valid if hidden. I think. But SEO is inefficient from a 3D imaging POV since there are extra steps for the model.
As for writing the object, unless there is a productivity payback or a specific technical requirement, why would you bother?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-03-03 05:15 PM
Seraphim wrote:If it's a one-off situation, model the Object. If it's an Object you may get a lot of use out of in multiple Projects, or you need the Object to be parametric, definitely script it (if you know how).
- « Previous
- Next »
- « Previous
- Next »
