‎2008-02-29
03:19 PM
‎2024-06-03
12:41 PM
Aruzhan Ilaikova
‎2008-03-02 04:17 AM
‎2008-03-02 04:24 AM
Dwight wrote:just don't be looking for a floor plan drawing at the same time though!
Ooo, baby!!!
‎2008-03-02 04:28 AM
‎2008-03-03 10:31 AM
~/archiben wrote:Good stuff!
definitely a wall - you can still put windows and doors in . . .
b
‎2008-03-03 04:29 PM
‎2008-03-03 04:49 PM
‎2008-03-03 05:15 PM
Seraphim wrote:
Whenever I create an object just to use it in an SEO operation is it bad to delete the object once the operation is performed? I see alot of references on the forums to simply placing the object on a hidden layer.
Seraphim wrote:If it's a one-off situation, model the Object. If it's an Object you may get a lot of use out of in multiple Projects, or you need the Object to be parametric, definitely script it (if you know how).
Also, do more practiced users tend to use SEO's for alot of their needs or create objects with scripting/modeling? So far I find it easier to create the object through scripting. But it seems like I should be more comfortable with SEO's and that SEO's would work quicker than writing several lines of code to get a desired shape.
